Aller au contenu principal
Introduction
Takes you through the steps to install the vibrator.
  1. Remove the back case with your fingernail to expose the battery. (Not shown in picture) Pull the black tab to remove the battery.
    • Remove the back case with your fingernail to expose the battery. (Not shown in picture)
    • Pull the black tab to remove the battery.
  2. Use a spudger to begin removal of the camera cover by inserting the flat end into the two notches and gently pry them up one at a time.
    • Use a spudger to begin removal of the camera cover by inserting the flat end into the two notches and gently pry them up one at a time.
  3. Work the spudger around the edge of the camera cover to release the clips. Work the spudger around the edge of the camera cover to release the clips.
    • Work the spudger around the edge of the camera cover to release the clips.
  4. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
    • Use a T5 Torx screwdriver to remove four 6mm screws that secure the back panel to the main body.
    • There is a screw under the "void" sticker.
  5. Device rotated 180 degrees. Insert the flat end of a spudger into the crack between the front and rear cover.
    • Device rotated 180 degrees.
    • Insert the flat end of a spudger into the crack between the front and rear cover.
    • Once you have enough of a gap to fit a plastic opening tool into it, use the opening tool to release the clips.
  6. Use the plastic opening tool to continue releasing the clips until you have worked your way around the edge. Use the plastic opening tool to continue releasing the clips until you have worked your way around the edge.
    • Use the plastic opening tool to continue releasing the clips until you have worked your way around the edge.
  7. Pull off the back case panel. Pull off the back case panel.
    • Pull off the back case panel.
  8. Use the tweezers to remove the vibrator module.
    • Use the tweezers to remove the vibrator module.
Kyle Champ
Membre depuis le 03/10/2011
204 Réputation
12 tutoriels rédigés
Équipe
Cal Poly, Team 20-27, Maness Fall 2011 Membre de l'équipe Cal Poly, Team 20-27, Maness Fall 2011
CPSU-MANESS-F11S20G27
4 membres
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 636
