Ce dont vous avez besoin
Press both thumbs on each side of the upper corners, and apply pressure in a downward motion.
While applying downward pressure, slide the back cover down and off the phone.
Remove the four 6 mm T5 Torx screws from the four corners on the back of the phone.
Remove the two 4 mm T5 Torx screws from the middle of the back of the phone.
Insert a spudger into the gap between the frame and cover. Push downward with the spudger to separate the back plate from the phone.
With the spudger in the gap between the frame and cover, move the spudger around the edge of the of the phone to finish removing the back plate.
Remove the 3 mm Phillips screw located on the side of the bottom left-hand corner of the phone.
Remove the 3 mm Phillips screw located on the top right-hand corner of the phone.
Place a finger between the circuit board and front cover, and lift the circuit board gently.
Separate the circuit board from the front cover and screen to access the ribbon cable holding them together. Detach the ribbon cable.
Finish separating the circuit board from the front panel.
After following the prerequisite guide listed above, the phone should have the circuit board housing group on one piece.
The front cover and screen of the phone should be located on the other piece.
