Aller au contenu principal
Hair Dryer Electrical Brushes Replacement
Ce dont vous avez besoin
  1. Hair Dryer Electrical Brushes Replacement, Electrical Brushes: étape 1, image 1 de 3 Hair Dryer Electrical Brushes Replacement, Electrical Brushes: étape 1, image 2 de 3 Hair Dryer Electrical Brushes Replacement, Electrical Brushes: étape 1, image 3 de 3
    • Make sure to unplug the device before beginning.
    • Rotate the stainless steel filter counterclockwise and pull upwards to remove it.
  2. Hair Dryer Electrical Brushes Replacement: étape 2, image 1 de 2 Hair Dryer Electrical Brushes Replacement: étape 2, image 2 de 2
    • Use a Phillips #1 screwdriver to remove the two screws securing the back cover.
  3. Hair Dryer Electrical Brushes Replacement: étape 3, image 1 de 3 Hair Dryer Electrical Brushes Replacement: étape 3, image 2 de 3 Hair Dryer Electrical Brushes Replacement: étape 3, image 3 de 3
    • Lift off the back cover.
  4. Hair Dryer Electrical Brushes Replacement: étape 4, image 1 de 3 Hair Dryer Electrical Brushes Replacement: étape 4, image 2 de 3 Hair Dryer Electrical Brushes Replacement: étape 4, image 3 de 3
    • Use a Phillips #1 screwdriver to remove the two screws securing the dryer motor.
    • Remove the motor from its plastic housing.
  5. Hair Dryer Electrical Brushes Replacement: étape 5, image 1 de 3 Hair Dryer Electrical Brushes Replacement: étape 5, image 2 de 3 Hair Dryer Electrical Brushes Replacement: étape 5, image 3 de 3
    • Unscrew the small plastic cap on the side of the motor and lift out the spring.
    • Remove the carbon electrical brush.
    • Repeat for the cap on the other side of the motor.
  6. Hair Dryer Electrical Brushes Replacement: étape 6, image 1 de 3 Hair Dryer Electrical Brushes Replacement: étape 6, image 2 de 3 Hair Dryer Electrical Brushes Replacement: étape 6, image 3 de 3
    • Install the new carbon brushes, and screw the caps back on.
    • Make sure the spring beneath the cap is properly positioned before tightening,
  7. Hair Dryer Electrical Brushes Replacement: étape 7, image 1 de 3 Hair Dryer Electrical Brushes Replacement: étape 7, image 2 de 3 Hair Dryer Electrical Brushes Replacement: étape 7, image 3 de 3
    • Place the motor back into the housing.
    • Rotate the motor clockwise to screw it into place.
    • Refasten the two motor screws using a Phillips #1 screwdriver.
  8. Hair Dryer Electrical Brushes Replacement: étape 8, image 1 de 3 Hair Dryer Electrical Brushes Replacement: étape 8, image 2 de 3 Hair Dryer Electrical Brushes Replacement: étape 8, image 3 de 3
    • Place the white wires coming off the motor back in the slots.
    • Place the diode in the slots.
  9. Hair Dryer Electrical Brushes Replacement: étape 9, image 1 de 2 Hair Dryer Electrical Brushes Replacement: étape 9, image 2 de 2
    • Set the power cord back in its slot.
  10. Hair Dryer Electrical Brushes Replacement: étape 10, image 1 de 3 Hair Dryer Electrical Brushes Replacement: étape 10, image 2 de 3 Hair Dryer Electrical Brushes Replacement: étape 10, image 3 de 3
    • Reinstall the back cover.
  11. Hair Dryer Electrical Brushes Replacement: étape 11, image 1 de 3 Hair Dryer Electrical Brushes Replacement: étape 11, image 2 de 3 Hair Dryer Electrical Brushes Replacement: étape 11, image 3 de 3
    • Place the two screws back in place and tighten them with a Phillips #1 screwdriver.
Enjoy your functional hair dryer!
Alejandra Medina
Membre depuis le 03/18/22
193 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 15
30 derniers jours : 68
Total : 1,445
