Aller au contenu principal
Hamilton Beach 48464 Heating Plate Replacement
Ce dont vous avez besoin
  1. Hamilton Beach 48464 Heating Plate Replacement, Heating Plate: étape 1, image 1 de 1
    • To begin, carefully open the top lid of the Brew Station.
  2. Hamilton Beach 48464 Heating Plate Replacement: étape 2, image 1 de 1
    • Gently pull out the filter basket from the Brew Station and set it to the side.
  3. Hamilton Beach 48464 Heating Plate Replacement: étape 3, image 1 de 1
    • Grab the handle and pull up to remove the top container.
    • Set this piece close by as you will be needing it for a future step.
  4. Hamilton Beach 48464 Heating Plate Replacement: étape 4, image 1 de 2 Hamilton Beach 48464 Heating Plate Replacement: étape 4, image 2 de 2
    • Using the Crown Bolt #8 Steel Spanner, unscrew the four 8-mm screws labeled in a red outline.
  5. Hamilton Beach 48464 Heating Plate Replacement: étape 5, image 1 de 2 Hamilton Beach 48464 Heating Plate Replacement: étape 5, image 2 de 2
    • Check again to make sure that the coffee maker is not plugged in.
    • Once the screws are removed, carefully pull off the metal piece.
    • Once the piece is removed, you will be able to access the heater.
  6. Hamilton Beach 48464 Heating Plate Replacement: étape 6, image 1 de 2 Hamilton Beach 48464 Heating Plate Replacement: étape 6, image 2 de 2
    • This step involves using the top contained that you put aside in step 3.
    • Using the Philips 2 Screwdriver, unscrew the eight 8-mm screws labeled in a red outline.
  7. Hamilton Beach 48464 Heating Plate Replacement: étape 7, image 1 de 1
    • Once screws are removed, carefully pull out the metal piece from the unit. This is the top part of the heater in the Brew Staton.
    • There are rubber washers inside each of the 8 holes on the piece of metal. Be careful to not let any fall out when handling the piece.
Michael Damico
Membre depuis le 02/10/16
661 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 14-1, Lacy Spring 2016 Membre de l'équipe USF Tampa, Team 14-1, Lacy Spring 2016
USFT-LACY-S16S14G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 17
Total : 971
