Aller au contenu principal
Hamilton Beach 48464 Power Cord Replacement
Ce dont vous avez besoin
  1. Hamilton Beach 48464 Power Cord Replacement, Base: étape 1, image 1 de 1
    • This is what the bottom cover will look like. Flip the Brew Station upside down to easily access the screws.
  2. Hamilton Beach 48464 Power Cord Replacement: étape 2, image 1 de 3 Hamilton Beach 48464 Power Cord Replacement: étape 2, image 2 de 3 Hamilton Beach 48464 Power Cord Replacement: étape 2, image 3 de 3
    • Using the Philips 2 Screwdriver, unscrew the three 8-mm screws labeled in a red outline.
    • Using the Crown Bolt #8 Steel Spanner, unscrew the two 8-mm screws labeled in a orange outline.
  3. Hamilton Beach 48464 Power Cord Replacement: étape 3, image 1 de 1
    • Carefully slide off the bottom drip tray by sliding it out away from the Brew Station.
  4. Hamilton Beach 48464 Power Cord Replacement: étape 4, image 1 de 1
    • Gently lift the base away from the Brew Station.
  5. Hamilton Beach 48464 Power Cord Replacement, Power Cord: étape 5, image 1 de 2 Hamilton Beach 48464 Power Cord Replacement, Power Cord: étape 5, image 2 de 2
    • Using the Philips 2 Screwdriver, unscrew the two 8-mm screws labeled in a red outline.
  6. Hamilton Beach 48464 Power Cord Replacement: étape 6, image 1 de 1
    • Using the Philips 2 Screwdriver, unscrew the two 8-mm screws labeled in a red outline. This will release the bracket that is holding down the large piece in the middle.
  7. Hamilton Beach 48464 Power Cord Replacement: étape 7, image 1 de 1
    • Using one hand, gently lift the large silver piece out of the base.
    • The silver piece will still be connected to the Brew Station, so handy it with care.
  8. Hamilton Beach 48464 Power Cord Replacement: étape 8, image 1 de 1
    • Once the screw is out, gently lift the white circuit board out of the base. This will be where the power cord begins, so you will now have access to the full length of the cord.
Michael Damico
Membre depuis le 02/10/16
661 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 14-1, Lacy Spring 2016 Membre de l'équipe USF Tampa, Team 14-1, Lacy Spring 2016
USFT-LACY-S16S14G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 12
Total : 262
