Aller au contenu principal
Hamilton Beach 48464 Tubing Replacement
Ce dont vous avez besoin
  1. Hamilton Beach 48464 Tubing Replacement, Filter Basket: étape 1, image 1 de 2 Hamilton Beach 48464 Tubing Replacement, Filter Basket: étape 1, image 2 de 2
    • Carefully open the top lid of the Brew Station.
  2. Hamilton Beach 48464 Tubing Replacement: étape 2, image 1 de 1
    • Slide out the filter basket that is sitting on top after opening the lid.
  3. Hamilton Beach 48464 Tubing Replacement, Tubing: étape 3, image 1 de 2 Hamilton Beach 48464 Tubing Replacement, Tubing: étape 3, image 2 de 2
    • Using the Philips 2 Screwdriver, unscrew the two 8-mm screws labeled in a red outline.
    • Once screws are removed, pull off the little circle piece.
  4. Hamilton Beach 48464 Tubing Replacement: étape 4, image 1 de 2 Hamilton Beach 48464 Tubing Replacement: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Using tweezers, grab the tube that is exposed after you pulled the piece off in step 1 and pull it up and out of the Brew Station.
  5. Hamilton Beach 48464 Tubing Replacement: étape 5, image 1 de 2 Hamilton Beach 48464 Tubing Replacement: étape 5, image 2 de 2
    • Using the Philips 2 Screwdriver, unscrew the three 8-mm screws labeled in a red outline.
    • Once screws are removed, gently pull off the liner that is on the inside of the lid.
  6. Hamilton Beach 48464 Tubing Replacement: étape 6, image 1 de 2 Hamilton Beach 48464 Tubing Replacement: étape 6, image 2 de 2
    • After completing Step 3, you will be exposed to a little piece attached to the inside of the lid. Pull this piece out, as it is the last piece of tubing used in the Brew Station.
Michael Damico
Membre depuis le 02/10/16
661 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 14-1, Lacy Spring 2016 Membre de l'équipe USF Tampa, Team 14-1, Lacy Spring 2016
USFT-LACY-S16S14G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 17
Total : 807
