Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Hamilton Beach 51101BA Motor Replacement
Ce dont vous avez besoin
    1. Hamilton Beach 51101BA Motor Replacement, Rotor: étape 1, image 1 de 3 Hamilton Beach 51101BA Motor Replacement, Rotor: étape 1, image 2 de 3 Hamilton Beach 51101BA Motor Replacement, Rotor: étape 1, image 3 de 3
      • Remove the container from the blender.
      • Hold the blender and the container, then twist the container in a clockwise motion.
      • Make sure to follow the lock and unlock markings on the container.
      Demander à FixBot
      Ajouter un commentaire
    2. Hamilton Beach 51101BA Motor Replacement: étape 2, image 1 de 1
      • Turn the blender so the bottom is facing you.
      • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
      Demander à FixBot
    3. Hamilton Beach 51101BA Motor Replacement: étape 3, image 1 de 1
      • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the motor platform.
      Demander à FixBot
    4. Hamilton Beach 51101BA Motor Replacement: étape 4, image 1 de 1
      • Unhinge the plastic motor platform from the blender.
      • You may need a plastic spudger to unhinge the motor platform from the blender.
      Demander à FixBot
    5. Hamilton Beach 51101BA Motor Replacement: étape 5, image 1 de 2 Hamilton Beach 51101BA Motor Replacement: étape 5, image 2 de 2
      • Using a spudger, carefully insert the tip into the coil of wire around motor.
      • This is used to hold the rotating piece of the motor still.
      Demander à FixBot
    6. Hamilton Beach 51101BA Motor Replacement: étape 6, image 1 de 1
      • Remove the white rotor piece by rotating it counter-clockwise.
      • While rotating, make sure the rotating piece of the motor remains still.
      Demander à FixBot
    1. Hamilton Beach 51101BA Motor Replacement, Motor: étape 7, image 1 de 2 Hamilton Beach 51101BA Motor Replacement, Motor: étape 7, image 2 de 2
      • Move the motor platform to the side.
      • Lift up the motor and remove it from the blender.
      Demander à FixBot
    2. Hamilton Beach 51101BA Motor Replacement: étape 8, image 1 de 1
      • Some soldering experience required!
      • Desolder the red wire from the green plastic piece.
      Demander à FixBot
    3. Hamilton Beach 51101BA Motor Replacement: étape 9, image 1 de 1
      • Cut the thin black wire from the wire cap.
      Demander à FixBot
Andrew Huff
Membre depuis le 09/04/15
616 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 2-5, Sullivan Fall 2015 Membre de l'équipe USF Tampa, Team 2-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G5
4 membres
11 tutoriels rédigés
2 commentaires de tutoriel
This article appears to be unfinished. You cut 2 wires at the end... then what? Reconnecting them doesn't make any sense.
Geo Jack Jack - Réponse Partager
Que tipo de motor tengo que comprar?
hugoalex521 - Réponse Partager
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 23
30 derniers jours : 87
Total : 8,912
