Aller au contenu principal
Hamilton Beach 64650 Motor Replacement
Ce dont vous avez besoin
  1. Hamilton Beach 64650 Motor Replacement, Motor: étape 1, image 1 de 3 Hamilton Beach 64650 Motor Replacement, Motor: étape 1, image 2 de 3 Hamilton Beach 64650 Motor Replacement, Motor: étape 1, image 3 de 3
    • Flip the handle on its side. Remove five 3.8 mm Philips #2 screws shown and set aside them aside.
  2. Hamilton Beach 64650 Motor Replacement: étape 2, image 1 de 3 Hamilton Beach 64650 Motor Replacement: étape 2, image 2 de 3 Hamilton Beach 64650 Motor Replacement: étape 2, image 3 de 3
    • Remove the four 8.6 mm Philips #2 screws securing the motor mount and place them aside.
  3. Hamilton Beach 64650 Motor Replacement: étape 3, image 1 de 3 Hamilton Beach 64650 Motor Replacement: étape 3, image 2 de 3 Hamilton Beach 64650 Motor Replacement: étape 3, image 3 de 3
    • Carefully pull the motor block out of the case.
    • Collect the two spring located on top of the white beater gears. The springs are held in place with compression, and may fall into the case when the motor is moved.
    • Handle the wires with care to ensure you do not break any of them.
  4. Hamilton Beach 64650 Motor Replacement: étape 4, image 1 de 3 Hamilton Beach 64650 Motor Replacement: étape 4, image 2 de 3 Hamilton Beach 64650 Motor Replacement: étape 4, image 3 de 3
    • Desolder the six wires connected to the motor using this guide.
    • Make sure to note colors when you disconnect them and remember where to reconnect them later.
  5. Hamilton Beach 64650 Motor Replacement: étape 5, image 1 de 2 Hamilton Beach 64650 Motor Replacement: étape 5, image 2 de 2
    • Once disconnected, the motor will slide out easily.
Gwen Davis
Membre depuis le 03/24/16
519 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 7-3, Catania Spring 2016 Membre de l'équipe UMass Dartmouth, Team 7-3, Catania Spring 2016
UMASSD-CATANIA-S16S7G3
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 48
Total : 2,084
