Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Hamilton Beach 64650 Speed Level Replacement
Ce dont vous avez besoin
    1. Hamilton Beach 64650 Speed Level Replacement, Motor: étape 1, image 1 de 3 Hamilton Beach 64650 Speed Level Replacement, Motor: étape 1, image 2 de 3 Hamilton Beach 64650 Speed Level Replacement, Motor: étape 1, image 3 de 3
      • Flip the handle on its side. Remove five 3.8 mm Philips #2 screws shown and set aside them aside.
      Demander à FixBot
      Ajouter un commentaire
    2. Hamilton Beach 64650 Speed Level Replacement: étape 2, image 1 de 3 Hamilton Beach 64650 Speed Level Replacement: étape 2, image 2 de 3 Hamilton Beach 64650 Speed Level Replacement: étape 2, image 3 de 3
      • Remove the four 8.6 mm Philips #2 screws securing the motor mount and place them aside.
      Demander à FixBot
    3. Hamilton Beach 64650 Speed Level Replacement: étape 3, image 1 de 3 Hamilton Beach 64650 Speed Level Replacement: étape 3, image 2 de 3 Hamilton Beach 64650 Speed Level Replacement: étape 3, image 3 de 3
      • Carefully pull the motor block out of the case.
      • Collect the two spring located on top of the white beater gears. The springs are held in place with compression, and may fall into the case when the motor is moved.
      • Handle the wires with care to ensure you do not break any of them.
      Demander à FixBot
    4. Hamilton Beach 64650 Speed Level Replacement: étape 4, image 1 de 3 Hamilton Beach 64650 Speed Level Replacement: étape 4, image 2 de 3 Hamilton Beach 64650 Speed Level Replacement: étape 4, image 3 de 3
      • Desolder the six wires connected to the motor using this guide.
      • Make sure to note colors when you disconnect them and remember where to reconnect them later.
      Demander à FixBot
    5. Hamilton Beach 64650 Speed Level Replacement: étape 5, image 1 de 2 Hamilton Beach 64650 Speed Level Replacement: étape 5, image 2 de 2
      • Once disconnected, the motor will slide out easily.
      Demander à FixBot
    1. Hamilton Beach 64650 Speed Level Replacement, Speed Level: étape 6, image 1 de 3 Hamilton Beach 64650 Speed Level Replacement, Speed Level: étape 6, image 2 de 3 Hamilton Beach 64650 Speed Level Replacement, Speed Level: étape 6, image 3 de 3
      • Remove the seven 5.6 mm Philips #2 screws that attach the motor casing to the mixer handle and set them aside.
      Demander à FixBot
    2. Hamilton Beach 64650 Speed Level Replacement: étape 7, image 1 de 3 Hamilton Beach 64650 Speed Level Replacement: étape 7, image 2 de 3 Hamilton Beach 64650 Speed Level Replacement: étape 7, image 3 de 3
      • Use a plastic opening tool to take off the handle's cap by loosening both ends and then sliding the tool to the middle of the handle.
      Demander à FixBot
    3. Hamilton Beach 64650 Speed Level Replacement: étape 8, image 1 de 2 Hamilton Beach 64650 Speed Level Replacement: étape 8, image 2 de 2
      • Remove the handle's cap carefully.
      • Watch out for the quick burst button, it likes to run away.
      Demander à FixBot
    4. Hamilton Beach 64650 Speed Level Replacement: étape 9, image 1 de 3 Hamilton Beach 64650 Speed Level Replacement: étape 9, image 2 de 3 Hamilton Beach 64650 Speed Level Replacement: étape 9, image 3 de 3
      • Slide the speed switch forward and lift upward off of the handle.
      Demander à FixBot
    5. Hamilton Beach 64650 Speed Level Replacement: étape 10, image 1 de 2 Hamilton Beach 64650 Speed Level Replacement: étape 10, image 2 de 2
      • Remove speed level from the inside of the case by applying light pressure toward you.
      • Do not pull on the wires to remove the speed level.
      Demander à FixBot
    6. Hamilton Beach 64650 Speed Level Replacement: étape 11, image 1 de 3 Hamilton Beach 64650 Speed Level Replacement: étape 11, image 2 de 3 Hamilton Beach 64650 Speed Level Replacement: étape 11, image 3 de 3
      • Remove the beater release button from speed level by removing the two 1.3 mm Philips #2 screws.
      • Replace the speed level assembly.
      Demander à FixBot
Gwen Davis
Membre depuis le 03/24/16
519 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 7-3, Catania Spring 2016 Membre de l'équipe UMass Dartmouth, Team 7-3, Catania Spring 2016
UMASSD-CATANIA-S16S7G3
3 membres
10 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 24
Total : 877
