Aller au contenu principal
Hamilton G5 Internal and Extended Battery Replacement
Matériel médical
Ni iFixit ni ce tutoriel de réparation ne sont approuvés par ou affiliés au fabricant de ce dispositif médical.
Ce dont vous avez besoin
  1. Hamilton G5 Internal and Extended Battery Replacement, Rail: étape 1, image 1 de 1
    • Remove 4 Hex Allen screws (A) from the Rail surrounding the Ventilation Unit.
  2. Hamilton G5 Internal and Extended Battery Replacement: étape 2, image 1 de 1
    • Remove the Rail (B).
  3. Hamilton G5 Internal and Extended Battery Replacement: étape 3, image 1 de 1
    • The Standoff Brackets (C) remain with the Main Cover.
    • Place aside in a safe location.
  4. Hamilton G5 Internal and Extended Battery Replacement, Main Cover: étape 5, image 1 de 1
    • Lift the Main Cover (A) from the Ventilation Unit using the Standoff Brackets (B) attached to the Main Cover.
  5. Hamilton G5 Internal and Extended Battery Replacement, Internal and Extended Battery: étape 7, image 1 de 1
    • Unscrew the 4 Hex Allen M4x8 screws (A), 2 on each side of the cover.
    • Lower the Front Cover (B) to remove it.
    • Disconnect the Alarm Status Display Connector (D) and set aside.
  6. Hamilton G5 Internal and Extended Battery Replacement: étape 8, image 1 de 1
    • Remove the 8 Hex Allen screws M4x8 (A) located on the side of the ventilator.
    • Locate internal battery (B) and slide it out.
    • Disconnect battery cable (C) and fully remove battery assembly.
  7. Hamilton G5 Internal and Extended Battery Replacement: étape 9, image 1 de 1
    • Remove 2 Hex Nuts, Washers, (D) and Cross Bar (E) from assembly.
    • Slide internal battery out from battery assembly.
  8. Hamilton G5 Internal and Extended Battery Replacement: étape 10, image 1 de 1
    • Extended Battery
    • Depress battery latch on right side (follow yellow arrow in image).
    • Slide the battery out of bracket to remove.
Heidi Silk
Membre depuis le 04/07/20
139 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S7-G25, Paton Spring 2020 Membre de l'équipe Cal Poly, Team S7-G25, Paton Spring 2020
CPSU-PATON-S20S7G25
6 membres
11 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 21
Total : 667
