Aller au contenu principal
Hamilton G5 Ventilation Unit Motherboard Replacement
Matériel médical
Ni iFixit ni ce tutoriel de réparation ne sont approuvés par ou affiliés au fabricant de ce dispositif médical.
Ce dont vous avez besoin
  1. Hamilton G5 Ventilation Unit Motherboard Replacement, Rail: étape 1, image 1 de 1
    • Remove 4 Hex Allen screws (A) from the Rail surrounding the Ventilation Unit.
  2. Hamilton G5 Ventilation Unit Motherboard Replacement: étape 2, image 1 de 1
    • Remove the Rail (B).
  3. Hamilton G5 Ventilation Unit Motherboard Replacement: étape 3, image 1 de 1
    • The Standoff Brackets (C) remain with the Main Cover.
    • Place aside in a safe location.
  4. Hamilton G5 Ventilation Unit Motherboard Replacement, Main Cover: étape 5, image 1 de 1
    • Lift the Main Cover (A) from the Ventilation Unit using the Standoff Brackets (B) attached to the Main Cover.
  5. Hamilton G5 Ventilation Unit Motherboard Replacement, Ventilation Unit Motherboard: étape 7, image 1 de 1
    • First, we need to remove the ESM module. It is connected to 2 connector sockets. Disconnect and remove.
    • Take out the Ventilation Real-time Controller (VRC) SW chip
  6. Hamilton G5 Ventilation Unit Motherboard Replacement: étape 9, image 1 de 1
    • Install the ESM Module, by connecting the connectors (A), and the VRC SW chip on the new board.
  7. Hamilton G5 Ventilation Unit Motherboard Replacement: étape 10, image 1 de 1
    • Disconnect all cables and connections from the board to the unit.
  8. Hamilton G5 Ventilation Unit Motherboard Replacement: étape 11, image 1 de 1
    • Remove the three Hex screws (B).
  9. Hamilton G5 Ventilation Unit Motherboard Replacement: étape 12, image 1 de 1
    • Move the motherboard out then up away from the ventilation unit (C).
Dane Dormedy
Membre depuis le 04/08/20
349 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S7-G25, Paton Spring 2020 Membre de l'équipe Cal Poly, Team S7-G25, Paton Spring 2020
CPSU-PATON-S20S7G25
6 membres
11 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 315
