Aller au contenu principal
Hand-Held Blender Motor Replacement
Ce dont vous avez besoin
  1. Hand-Held Blender Motor Replacement, Motor: étape 1, image 1 de 1
    • Place the product on a clean and empty surface.
  2. Hand-Held Blender Motor Replacement: étape 2, image 1 de 1
    • Twist the attachment with the blades from the base of the blender.
  3. Hand-Held Blender Motor Replacement: étape 3, image 1 de 1
    • Unscrew the Tri-point screw (2mm) on the top to disassemble the top part of the casing.
  4. Hand-Held Blender Motor Replacement: étape 4, image 1 de 1
    • Unscrew the Phillips (2mm) connecting the middle part of the casing with the bottom part.
  5. Hand-Held Blender Motor Replacement: étape 5, image 1 de 1
    • Use force to twist the middle part from the bottom part of the casing OR use spudgers to wiggle open the product.
    • This reveals the motor.
  6. Hand-Held Blender Motor Replacement: étape 6, image 1 de 1
    • Lift the motor out of the casing.
    • Unscrew the Phillips (2mm) to disconnect the motor from the plastic part that transfers the motor rotations to the blade.
  7. Hand-Held Blender Motor Replacement: étape 7, image 1 de 1
    • With a soldering iron disconnect the wires coming from the motor from the PCB.
    • Refer to this How to Solder and Desolder Connections guide to find more information on proper soldering techniques.
Nina Rodenburg
Membre depuis le 03/08/17
109 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 15
30 derniers jours : 78
Total : 3,361
