Aller au contenu principal
Handheld Toilet Bidet Sprayer Replacement
Ce dont vous avez besoin
  1. Handheld Toilet Bidet Sprayer Replacement, Handheld Toilet Bidet Sprayer: étape 1, image 1 de 1
    • Turn off the toilet water valve by turning the knob clockwise.
  2. Handheld Toilet Bidet Sprayer Replacement: étape 2, image 1 de 1
    • Flush the toilet until no water is left in the tank.
  3. Handheld Toilet Bidet Sprayer Replacement: étape 3, image 1 de 1
    • Place a towel under the tank incase of any water drops.
  4. Handheld Toilet Bidet Sprayer Replacement: étape 4, image 1 de 1
    • Unscrew the water supply line from the T-connector by turning the knob counterclockwise.
  5. Handheld Toilet Bidet Sprayer Replacement: étape 5, image 1 de 1
    • Unscrew the hose from the T-connector by turning the knob counterclockwise.
  6. Handheld Toilet Bidet Sprayer Replacement: étape 6, image 1 de 1
    • Unscrew the T-connector from the toilet by turning the knob counterclockwise.
  7. Handheld Toilet Bidet Sprayer Replacement: étape 7, image 1 de 3 Handheld Toilet Bidet Sprayer Replacement: étape 7, image 2 de 3 Handheld Toilet Bidet Sprayer Replacement: étape 7, image 3 de 3
    • Install the toilet sprayer's rubber on the water supply hose from the side that is causing a water leak. This will stop water leaking from the hose.
  8. Handheld Toilet Bidet Sprayer Replacement: étape 8, image 1 de 1
    • Screw the T-connector back on the toilet by turning the knob clockwise.
    • Be careful not to cross the threads.
  9. Handheld Toilet Bidet Sprayer Replacement: étape 9, image 1 de 1
    • Screw the water supply nut onto the bottom of the T-connector by turning the knob clockwise. Make sure it is firmly hand tight.
  10. Handheld Toilet Bidet Sprayer Replacement: étape 10, image 1 de 1
    • Screw the water supply hose back on the T-connector by turning the knob clockwise. Be sure not to over tighten the nut.
  11. Handheld Toilet Bidet Sprayer Replacement: étape 11, image 1 de 1
    • Turn on the toilet water valve by turning the knob counterclockwise. now, you can test your water and spray it through the hose. Make sure there is no water leaking.
Ligne d'arrivée
Almuhannad Althurwi
Membre depuis le 06/29/18
201 Réputation
1 tutoriel rédigé
2 commentaires
If this is used as a bidet, wouldn’t the water be awfully cold? Almost too invigorating. If just used to help clean the toilet, okay.
Pete
Pete Chisteckoff - Réponse
Same concern.
Nuke Engineer -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 14
30 derniers jours : 82
Total : 9,967
