Introduction
By replacing the electro motor, which powers the blades in the fan, users kan keep using their fan heater for much longer. This electro motor (yj58-12a1) is very easy to acquire online, and fairly easy to replace.
We will provide a step-by-step manual to disassemble the fan heater down to the motor by unscrewing the housing and the parts inside the housing, taking the parts apart, cutting the wire, connecting the new wire and engine to the old wire and assembling the whole thing back together.
Minimal tools are needed to do so. We used Pozidrive screwdrivers (1x75), a small pick, pliers, stripping pliers, heat shrink sleeves, a lighter and some lubricant to disassemble the product and replace the motor.
Ce dont vous avez besoin
Flip the device over so the bottom is revealed.
Unscrew the nine screws (3x12mm) using a Phillips (1x75) screwdriver to open up the housing of the fan heater.
Lay the heat shrink upon one of the wire halves.
Feather apart the electric wire on both halves.
Weave together the wiring of the two halves so they create one wire.
Shove the heat shrink over the woven electric wire.
Use a heater such as a blowdryer or lighter to warm up the heat shrink and seal the wire halves.
3 autres ont terminé cette réparation.
