Introduction
This guide will show you how to remove and replace the Fan/MotherBoard in the Hannspree SN12E2 laptop. The Fan is used to cool your CPU and stop your device from overheating. If your device is running hot or crashing all together this may be the solution. In the Hannspree SN12E2 the Fan is attached to the motherboard so you would need to replace both in this guide.
Ce dont vous avez besoin
Remove 3.4mm PH0 retaining screws as well as the three 3mm PH0 fan screws
