Aller au contenu principal
Hannspree SN12E2 IO Board Replacement
Ce dont vous avez besoin
  1. Hannspree SN12E2 IO Board Replacement, Battery: étape 1, image 1 de 1
    • Unplug and power off your laptop.
  2. Hannspree SN12E2 IO Board Replacement: étape 2, image 1 de 1
    • Close your laptop .
    • Place your laptop face down on a flat surface.
  3. Hannspree SN12E2 IO Board Replacement: étape 3, image 1 de 3 Hannspree SN12E2 IO Board Replacement: étape 3, image 2 de 3 Hannspree SN12E2 IO Board Replacement: étape 3, image 3 de 3
    • Unlatch the lock on the top right of your laptop first.
    • You will need to pull on the lock on the left side and remove the battery at the same time
    • The left lock is a spring lock and needs constant pressure applied in order to stay open.
  4. Hannspree SN12E2 IO Board Replacement, Touchpad Plane/Keyboard: étape 4, image 1 de 1
    • Remove all the 5mm PH0 screws on the back cover
  5. Hannspree SN12E2 IO Board Replacement: étape 5, image 1 de 3 Hannspree SN12E2 IO Board Replacement: étape 5, image 2 de 3 Hannspree SN12E2 IO Board Replacement: étape 5, image 3 de 3
    • Gently pry the case apart starting at the lower right corner using the small spudger
    • Move around the case gently prying until the touchpad plane is free from the rest of the case
  6. Hannspree SN12E2 IO Board Replacement: étape 6, image 1 de 2 Hannspree SN12E2 IO Board Replacement: étape 6, image 2 de 2
    • Gently lift up on the touchpad portion of the touchpad plane
    • Unplug the ZIFF connector by pulling gently on the black retaining blade and removing the white flat flex cable
    • Pull the touchpad away from the rest of the case
  7. Hannspree SN12E2 IO Board Replacement: étape 7, image 1 de 1
    • Gently lift up on the loose keyboard to expose the ZIFF connector.
    • Unplug the keyboard ZIFF following the same instructions as the touchpad ZIFF
  8. Hannspree SN12E2 IO Board Replacement, Hard Drive Access Door: étape 8, image 1 de 1
    • Remove the three 3mm Phillips #0 screws.
  9. Hannspree SN12E2 IO Board Replacement: étape 9, image 1 de 1
    • Gently pull on the access panel to remove it.
  10. Hannspree SN12E2 IO Board Replacement, Hard Drive: étape 10, image 1 de 1
    • Remove the four 4mm Phillips #0 retaining screws.
    • The hard drive caddy is the large piece of metal with black circles.
  11. Hannspree SN12E2 IO Board Replacement: étape 11, image 1 de 1
    • Next, lift up the hard drive and pull towards you. Lift up the end of the hard drive that is not plugged into the computer.
  12. Hannspree SN12E2 IO Board Replacement: étape 12, image 1 de 2 Hannspree SN12E2 IO Board Replacement: étape 12, image 2 de 2
    • Slide your hard drive out of the metal piece by unscrewing the sides.
  13. Hannspree SN12E2 IO Board Replacement, IO Board: étape 13, image 1 de 1
    • Remove the three 3mm PH0 screws holding the IO board to the case.
  14. Hannspree SN12E2 IO Board Replacement: étape 14, image 1 de 3 Hannspree SN12E2 IO Board Replacement: étape 14, image 2 de 3 Hannspree SN12E2 IO Board Replacement: étape 14, image 3 de 3
    • Unplug the three JST connectors connecting the IO board to the motherboard.
    • For each connector, remove by gently pulling parallel to the connector housing until the connector becomes undone
    • When replacing the connectors ensure that they are oriented correctly. The housing is keyed to prevent the connectors from being plugged in backwards.
  15. Hannspree SN12E2 IO Board Replacement: étape 15, image 1 de 1
    • Remove IO Board by gently tilting it toward the outer edge of the case.
jacob
Membre depuis le 03/25/19
150 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S2-G2, Simcock Spring 2019 Membre de l'équipe UMass Dartmouth, Team S2-G2, Simcock Spring 2019
UMASSD-SIMCOCK-S19S2G2
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 121
