Aller au contenu principal
Hannspree SN12E2 Wifi Card Replacement
Ce dont vous avez besoin
  1. Hannspree SN12E2 Wifi Card Replacement, Battery: étape 1, image 1 de 1
    • Unplug and power off your laptop.
  2. Hannspree SN12E2 Wifi Card Replacement: étape 2, image 1 de 1
    • Close your laptop .
    • Place your laptop face down on a flat surface.
  3. Hannspree SN12E2 Wifi Card Replacement: étape 3, image 1 de 3 Hannspree SN12E2 Wifi Card Replacement: étape 3, image 2 de 3 Hannspree SN12E2 Wifi Card Replacement: étape 3, image 3 de 3
    • Unlatch the lock on the top right of your laptop first.
    • You will need to pull on the lock on the left side and remove the battery at the same time
    • The left lock is a spring lock and needs constant pressure applied in order to stay open.
  4. Hannspree SN12E2 Wifi Card Replacement, Hard Drive Access Door: étape 4, image 1 de 1
    • Remove the three 3mm Phillips #0 screws.
  5. Hannspree SN12E2 Wifi Card Replacement: étape 5, image 1 de 1
    • Gently pull on the access panel to remove it.
  6. Hannspree SN12E2 Wifi Card Replacement, Wifi Card: étape 6, image 1 de 2 Hannspree SN12E2 Wifi Card Replacement, Wifi Card: étape 6, image 2 de 2
    • Locate the Wifi Card in the bottom right of the hard drive access panel.
    • Remove the two antenna plugged into the the Wifi Card.
    • Remove the two 3.6mm PH0 screws.
  7. Hannspree SN12E2 Wifi Card Replacement: étape 7, image 1 de 1
    • Remove the Wifi Card by pulling it up and out towards yourself.
Kyle Duby
Membre depuis le 03/26/19
193 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G2, Simcock Spring 2019 Membre de l'équipe UMass Dartmouth, Team S2-G2, Simcock Spring 2019
UMASSD-SIMCOCK-S19S2G2
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 103
