Aller au contenu principal
Harman Kardon Esquire Mini External Stand Replacement
Ce dont vous avez besoin
  1. Harman Kardon Esquire Mini External Stand  Replacement, Front Panel: étape 1, image 1 de 1
    • Using the plastic opening tool, to open the back panel of the device. Start on the longer sides to avoid bending the metal frame at the plug ports.
    • Push down on the plastic opening tool, and push the back panel, repeat this for the 4 sides of the device.
  2. Harman Kardon Esquire Mini External Stand  Replacement: étape 2, image 1 de 1
    • Using the PH0 screw driver, remove the 7.5 mm screws by turning in a counter-clockwise direction. There are 6 screws on the front panel.
    • Remove all of the 7.5 mm screws, by repeating the same step above. It is not necessary to remove the stand-leg.
    • After unscrewing the 7.5 mm screws, just lift the plastic and you will see the motherboard.
  3. Harman Kardon Esquire Mini External Stand  Replacement, External Stand: étape 3, image 1 de 1
    • Using the Pentalobe screw driver, unscrew the 5.1 mm screws by applying a clockwise force.
    • Remove all of the 5.1 mm screws, and slowly lift the stand. There are 4 screws on the stand.
    • After the stand is removed, replace the stand with a new one.
yousef aljeemaz
Membre depuis le 10/18/17
1 039 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S1-G9, Cagle Fall 2017 Membre de l'équipe USF Tampa, Team S1-G9, Cagle Fall 2017
USFT-CAGLE-F17S1G9
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 607
