Aller au contenu principal
Harman Kardon Invoke Microphone on/off Button Replacement
Ce dont vous avez besoin
  1. Harman Kardon Invoke Microphone on/off Button Replacement, Remove the base: étape 1, image 1 de 2 Harman Kardon Invoke Microphone on/off Button Replacement, Remove the base: étape 1, image 2 de 2
    • Use a metal spudger to remove the rubber bottom.
  2. Harman Kardon Invoke Microphone on/off Button Replacement, Remove the base screws: étape 2, image 1 de 2 Harman Kardon Invoke Microphone on/off Button Replacement, Remove the base screws: étape 2, image 2 de 2
    • Use a Torx #10 screwdriver to remove the four 14.0 mm screws.
  3. Harman Kardon Invoke Microphone on/off Button Replacement, Remove the base: étape 3, image 1 de 2 Harman Kardon Invoke Microphone on/off Button Replacement, Remove the base: étape 3, image 2 de 2
    • Firmly grip the bottom and wiggle it upwards to remove the base.
  4. Harman Kardon Invoke Microphone on/off Button Replacement, Unscrew the board: étape 4, image 1 de 2 Harman Kardon Invoke Microphone on/off Button Replacement, Unscrew the board: étape 4, image 2 de 2
    • Use a Torx #10 screwdriver to remove three 10.0 mm screws from the highlighted board attached to microphone button.
  5. Harman Kardon Invoke Microphone on/off Button Replacement, Remove the board: étape 5, image 1 de 2 Harman Kardon Invoke Microphone on/off Button Replacement, Remove the board: étape 5, image 2 de 2
    • Pull the cable lightly to disconnect the button board from device.
    • To replace the microphone button, you will have to replace the entire smaller board.
Angel A. Grageda
Membre depuis le 10/02/18
686 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 7
30 derniers jours : 10
Total : 606
