Aller au contenu principal
Harman Kardon Onyx Studio 2 Circuit Board Replacement
Ce dont vous avez besoin
  1. Harman Kardon Onyx Studio 2 Circuit Board Replacement, Front Panel: étape 1, image 1 de 3 Harman Kardon Onyx Studio 2 Circuit Board Replacement, Front Panel: étape 1, image 2 de 3 Harman Kardon Onyx Studio 2 Circuit Board Replacement, Front Panel: étape 1, image 3 de 3
    • Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
  2. Harman Kardon Onyx Studio 2 Circuit Board Replacement: étape 2, image 1 de 2 Harman Kardon Onyx Studio 2 Circuit Board Replacement: étape 2, image 2 de 2
    • Remove the five 14.4 mm T10 Torx screws.
  3. Harman Kardon Onyx Studio 2 Circuit Board Replacement: étape 3, image 1 de 1
    • Gently pull the front apart from the back.
  4. Harman Kardon Onyx Studio 2 Circuit Board Replacement: étape 4, image 1 de 2 Harman Kardon Onyx Studio 2 Circuit Board Replacement: étape 4, image 2 de 2
    • Remove the four wires connecting the front and back panels.
    • Pinch the connector tab and pull gently upwards.
    • Repeat for the other three connectors.
  5. Harman Kardon Onyx Studio 2 Circuit Board Replacement, Control Board: étape 5, image 1 de 1
    • Pull the silicone button band off of the outer edge of the speaker.
  6. Harman Kardon Onyx Studio 2 Circuit Board Replacement: étape 6, image 1 de 2 Harman Kardon Onyx Studio 2 Circuit Board Replacement: étape 6, image 2 de 2
    • Disconnect the two pressure connections from the circuit board.
  7. Harman Kardon Onyx Studio 2 Circuit Board Replacement: étape 7, image 1 de 2 Harman Kardon Onyx Studio 2 Circuit Board Replacement: étape 7, image 2 de 2
    • Gently remove the control board band by placing fingers in contact with it through the button openings.
    • Work from the outer edges in so as not to bend the band.
  8. Harman Kardon Onyx Studio 2 Circuit Board Replacement, Circuit Board: étape 8, image 1 de 2 Harman Kardon Onyx Studio 2 Circuit Board Replacement, Circuit Board: étape 8, image 2 de 2
    • Disconnect the remaining connectors from the circuit board.
    • Disconnect the Bluetooth antenna.
  9. Harman Kardon Onyx Studio 2 Circuit Board Replacement: étape 9, image 1 de 2 Harman Kardon Onyx Studio 2 Circuit Board Replacement: étape 9, image 2 de 2
    • Remove the four 10 mm T10 Torx screws.
    • Pull the circuit board out of the device as it is now free.
11 autres ont terminé cette réparation.
Alexandra Achtenberg
Membre depuis le 02/02/17
2 046 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 16-5, Blackwell Spring 2017 Membre de l'équipe USF Tampa, Team 16-5, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G5
3 membres
24 tutoriels rédigés
5 commentaires
Where do I get another one
Adrian tlahuel - Réponse
Where we buy the board?
Eric Therrien - Réponse
Umm… this was rather anticlimactic. Last step was basically like “and now contemplate your life choices”.
markcendan - Réponse
Where can I Buy a new hk onix studio Main board?
tecnologia en localizaciòn - Réponse
My speaker was working great. I just disconnected my phone to make a call, put YouTube back on it was all mumbled & the big button in the back kept pulsing so fast.
Maureen Field - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 38
30 derniers jours : 117
Total : 21,542
