Aller au contenu principal
Hasbro Bop-It Micro Series Buttons Replacement
Ce dont vous avez besoin
  1. Hasbro Bop-It Micro Series Buttons Replacement, Back Case: étape 1, image 1 de 1
    • Loosen the two captive 8 mm screws in the back cover using a Phillips #0 screwdriver.
  2. Hasbro Bop-It Micro Series Buttons Replacement: étape 2, image 1 de 1
    • Remove the six 6 mm screws from the back cover using a Phillips #0 screwdriver.
    • When removing the final screw, hold the assembly together. There is a spring inside the device which will pop the assembly apart when all the screws are removed.
  3. Hasbro Bop-It Micro Series Buttons Replacement: étape 3, image 1 de 1
    • Carefully separate the two sections, leaving them connected by the wires.
  4. Hasbro Bop-It Micro Series Buttons Replacement, Buttons: étape 4, image 1 de 1
    • Remove the buttons by de-soldering them from the wires they are attached to or from the mother board. Refer to the soldering guide here.
  5. Hasbro Bop-It Micro Series Buttons Replacement: étape 5, image 1 de 1
    • After removing the buttons, solder new, operational buttons back into place.
3 autres ont terminé cette réparation.
Glenn Haag
Membre depuis le 09/29/16
479 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team 3-1, Harley Fall 2016 Membre de l'équipe IUPUI, Team 3-1, Harley Fall 2016
IUPUI-HARLEY-F16S3G1
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 27
Total : 1,902
