Aller au contenu principal
Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement
Ce dont vous avez besoin
  1. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, Batteries: étape 1, image 1 de 3 Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, Batteries: étape 1, image 2 de 3 Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, Batteries: étape 1, image 3 de 3
    • Find the removable panel at the bottom of the hand.
    • Use your finger to push upwards and open the panel.
    • Slide the panel off and separate it from the hand.
  2. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: étape 2, image 1 de 2 Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: étape 2, image 2 de 2
    • Remove the left-most battery by pushing down on the positive end and pulling it out.
    • Repeat this for the next two batteries.
  3. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, LED Lights: étape 3, image 1 de 1
    • Remove the screws within the gauntlet and surrounding the palm.
  4. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: étape 4, image 1 de 1
    • Open the gauntlet carefully, as there are wires connecting both sides.
    • Address which LED is faulty. Check if the wires connecting to it are all intact; If there is a detachment within the circuits, reconnect it to its location. The LED should operate in that instance.
  5. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: étape 5, image 1 de 1
    • To replace the LED chip, remove the screw holding the chip in place.
  6. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: étape 6, image 1 de 1
    • Ensure that the LED chip is in the correct area with the correct polarity.
    • Reconnect it to its respective surface and check if it fits with in the magnetic gem. If not, consider another replacement.
Jessica
Membre depuis le 02/24/23
109 Réputation
1 tutoriel rédigé
Équipe
Marist, Team 1-3, Chaterdon Spring 2023 Membre de l'équipe Marist, Team 1-3, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G3
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 16
Total : 230
