Aller au contenu principal
Hatch Restore Bottom Circuit Board Replacement
Ce dont vous avez besoin
  1. Hatch Restore Bottom Circuit Board Replacement, Intro: étape 1, image 1 de 2 Hatch Restore Bottom Circuit Board Replacement, Intro: étape 1, image 2 de 2
    • Replacing your bottom circuit board will be easy.
  2. Hatch Restore Bottom Circuit Board Replacement: étape 2, image 1 de 2 Hatch Restore Bottom Circuit Board Replacement: étape 2, image 2 de 2
    • Peel away the rubber feet.
  3. Hatch Restore Bottom Circuit Board Replacement: étape 3, image 1 de 2 Hatch Restore Bottom Circuit Board Replacement: étape 3, image 2 de 2
    • Remove the indicated 8 screws.
    • You may need to remove some adhesive from the screws to remove them.
  4. Hatch Restore Bottom Circuit Board Replacement: étape 4, image 1 de 2 Hatch Restore Bottom Circuit Board Replacement: étape 4, image 2 de 2
    • Pry off the bottom cover.
  5. Hatch Restore Bottom Circuit Board Replacement: étape 5, image 1 de 1
    • Remove the 6 indicated screws.
  6. Hatch Restore Bottom Circuit Board Replacement: étape 6, image 1 de 2 Hatch Restore Bottom Circuit Board Replacement: étape 6, image 2 de 2
    • Remove the power cable
    • There is a ribbon cable under the board. Do not pull the circuit board too far from the device.
  7. Hatch Restore Bottom Circuit Board Replacement: étape 7, image 1 de 2 Hatch Restore Bottom Circuit Board Replacement: étape 7, image 2 de 2
    • Push the black tabs on the ZIF connector towards the cable, then remove the cable.
    • The cable should have no resistance when pulled out. Do not forcefully remove the cable.
9021007
Membre depuis le 07/13/18
4 599 Réputation
25 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 19
Total : 261
