Aller au contenu principal
Havoc Heli IR LED Replacement
Ce dont vous avez besoin
  1. Havoc Heli IR LED  Replacement, Havoc Heli IR LED: étape 1, image 1 de 2 Havoc Heli IR LED  Replacement, Havoc Heli IR LED: étape 1, image 2 de 2
    • Power off the controller before disassembly.
    • Place a small piece of tape over the Light button to prevent it from falling out in later steps.
    • Flip the controller over so the back is facing up.
  2. Havoc Heli IR LED  Replacement: étape 2, image 1 de 3 Havoc Heli IR LED  Replacement: étape 2, image 2 de 3 Havoc Heli IR LED  Replacement: étape 2, image 3 de 3
    • Remove the battery compartment screw with a small Phillips screw driver.
    • Lift off the battery cover.
    • Remove the six AA batteries from the compartment.
  3. Havoc Heli IR LED  Replacement: étape 3, image 1 de 3 Havoc Heli IR LED  Replacement: étape 3, image 2 de 3 Havoc Heli IR LED  Replacement: étape 3, image 3 de 3
    • Remove the remaining four screws with a small Phillips screw driver.
    • Flip the device over so the front is facing up.
    • Remove the front cover and place it to the left side.
    • Make sure to note the locations of the joysticks and other controls in case they fall out of place during this or future steps.
  4. Havoc Heli IR LED  Replacement: étape 4, image 1 de 1
    • Lift up the red IR LED cover to remove it.
  5. Havoc Heli IR LED  Replacement: étape 5, image 1 de 2 Havoc Heli IR LED  Replacement: étape 5, image 2 de 2
    • Use the soldering iron and solder wick to remove the solder from the IR LED you're replacing.
    • Pull the LED out through the top.
  6. Havoc Heli IR LED  Replacement: étape 6, image 1 de 2 Havoc Heli IR LED  Replacement: étape 6, image 2 de 2
    • Insert the new LED into the slot.
    • Make sure that the short lead of the LED is on the right.
    • Use the soldering iron and solder to connect the new LED.
Michael Kent
Membre depuis le 03/30/16
128 Réputation
1 tutoriel rédigé
Équipe
Michigan Tech, Team 1-13, Lauer Fall 2016 Membre de l'équipe Michigan Tech, Team 1-13, Lauer Fall 2016
MTU-LAUER-F16S1G13
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 552
