Aller au contenu principal
Head Cleaning v3
Ce dont vous avez besoin
  1. Head Cleaning v3, Setting Up the Printer: étape 1, image 1 de 2 Head Cleaning v3, Setting Up the Printer: étape 1, image 2 de 2
    • With the printer switched on, access the menu screen and select the option "Quick Configuration".
    • In the Quick Configuration menu select the option "Back off the Table".
  2. Head Cleaning v3, Repositing table: étape 2, image 1 de 3 Head Cleaning v3, Repositing table: étape 2, image 2 de 3 Head Cleaning v3, Repositing table: étape 2, image 3 de 3
    • When the table reach the position indicated in the picture, press the Reset button on the left side of the machine as shown.
    • Select the option "Pre-heat PLA" in the Quick Configuration menu.
  3. Head Cleaning v3, Repositioning the head: étape 3, image 1 de 2 Head Cleaning v3, Repositioning the head: étape 3, image 2 de 2
    • With the table in position push the head manually toward the machine center in order to obtain an easy handling.
  4. Head Cleaning v3, Removing the nozzle: étape 4, image 1 de 3 Head Cleaning v3, Removing the nozzle: étape 4, image 2 de 3 Head Cleaning v3, Removing the nozzle: étape 4, image 3 de 3
    • Position the 17mm Fixed Key as indicated in the picture, locking the inner part of the head to prevent the nozzle head from turning.
    • WIth the 7mm wrench take off the nozzle head.
  5. Head Cleaning v3, Removing the upper PTFE: étape 5, image 1 de 2 Head Cleaning v3, Removing the upper PTFE: étape 5, image 2 de 2
    • With your hands, pull out the PTFE tube from the printhead by pressing the black piece of the part where the tube is seated
  6. Head Cleaning v3, Removing the inner PTFE: étape 6, image 1 de 3 Head Cleaning v3, Removing the inner PTFE: étape 6, image 2 de 3 Head Cleaning v3, Removing the inner PTFE: étape 6, image 3 de 3
    • By positioning the drill bit into the indicated hole, push it down until the inner PTFE comes out from under the head (where the nozzle hole is).
  7. Head Cleaning v3, Replacement and cleaning: étape 7, image 1 de 3 Head Cleaning v3, Replacement and cleaning: étape 7, image 2 de 3 Head Cleaning v3, Replacement and cleaning: étape 7, image 3 de 3
    • Finish removing the inner PTFE and replace it with a new one or clean it.
    • With the drill bit, clean the nozzle hole, as shown in the figure.
    • Insert the new inner PTFE in place as shown.
  8. Head Cleaning v3, Reassembling the head: étape 8, image 1 de 3 Head Cleaning v3, Reassembling the head: étape 8, image 2 de 3 Head Cleaning v3, Reassembling the head: étape 8, image 3 de 3
    • Replace the nozzle at the bottom of the printhead and the PTFE at the top, pushing it all the way with your hands.
  9. Head Cleaning v3, Returning the table to start position: étape 9, image 1 de 2 Head Cleaning v3, Returning the table to start position: étape 9, image 2 de 2
    • Reposition the table in the "Home XYZ" menu option in the fast settings section and wait until it is in the position indicated by the figure
You are ready to continue your impressions!
Merci à ces traducteurs :
pt en
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Mousta Impressoras 3D
Membre depuis le 03/17/17
691 Réputation
5 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 12
Total : 623
