Introduction
This is a quick, super simple replacement that can be done in the lot of the auto parts store. Good luck!
Outils
Aucun outil requis.
Pièces
  1. Before you begin, make sure you have the right bulb.  I got this at the local autozone.
    • Before you begin, make sure you have the right bulb. I got this at the local autozone.
    • Do NOT touch the glass of the bulb. The oils from your fingers can drastically reduce the life of the bulb.
      • Vinyl or latex gloves are great if you have them available, but not required.
  2. Press firmly on the plugs clip and pull to remove the power cable from the bulb. Press firmly on the plugs clip and pull to remove the power cable from the bulb.
    • Press firmly on the plugs clip and pull to remove the power cable from the bulb.
  3. %Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
    Vous avez déjà réparé quelque chose ? Vous êtes un génie.
    Partagez votre réparation avec le hashtag #ImAGenius
    Nous sommes tous des génies
  4. Lift up and remove the metal wire cage holding the bulb in place. Lift up and remove the metal wire cage holding the bulb in place. Lift up and remove the metal wire cage holding the bulb in place.
    • Lift up and remove the metal wire cage holding the bulb in place.
  5. Remove the bulb by pulling it away from the headlight enclosure.
    • Remove the bulb by pulling it away from the headlight enclosure.
    • Once the old bulb is removed, take your new one and place it in the headlight.
    • Follow the steps in reverse to secure the new bulb in the headlight.
To replace the bulb, follow the steps in reverse order.
Tim Asp
Membre depuis le 24/01/2011
1 297 Réputation
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 14
Total : 2,896
