Introduction
We will replace the front (plastic) case of the Hello Zee Smart Core.
Ce dont vous avez besoin
Insert the spudger into a corner and separate the halves
Do not puncture the battery
Use your spudger to pry up the board from the sides
Do not break it
Do not pry from the battery side
CAREFULLY pry under the battery to remove it
there are no permanent adhesives, though there may be sticky tape
Spectate everything from the case
To reassemble your device, follow these instructions in reverse order, using your replacement case instead of the one described.
