Aller au contenu principal
Heyday Round Bluetooth Speaker Motherboard Replacement
Ce dont vous avez besoin
  1. Heyday Round Bluetooth Speaker Motherboard Replacement, Heyday Round Bluetooth Speaker Disassembly: étape 1, image 1 de 2 Heyday Round Bluetooth Speaker Motherboard Replacement, Heyday Round Bluetooth Speaker Disassembly: étape 1, image 2 de 2
    • Use a metal spudger to pry the fabric-covered top off of the speaker.
  2. Heyday Round Bluetooth Speaker Motherboard Replacement: étape 2, image 1 de 3 Heyday Round Bluetooth Speaker Motherboard Replacement: étape 2, image 2 de 3 Heyday Round Bluetooth Speaker Motherboard Replacement: étape 2, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the twelve screws around the perimeter of the inner plastic shell.
    • Remove the inner shell from the back case.
    • Don't yank or pull the shell case off the bottom case. There are cables connecting the two and they could be damaged if pulled.
  3. Heyday Round Bluetooth Speaker Motherboard Replacement, Motherboard: étape 3, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the two screws holding the motherboard in place.
  4. Heyday Round Bluetooth Speaker Motherboard Replacement: étape 4, image 1 de 2 Heyday Round Bluetooth Speaker Motherboard Replacement: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use a pair of tweezers to disconnect the yellow wire from the motherboard by pinching the input and pulling away from the motherboard.
  5. Heyday Round Bluetooth Speaker Motherboard Replacement: étape 5, image 1 de 1
    • Carefully remove the motherboard by sliding it upwards.
Jonathan Sotelo
Membre depuis le 09/22/22
302 Réputation
2 tutoriels rédigés
Équipe
Un commentaire
I have a Harman kardon onyx studio 5 speaker and it stop working, so I open it and discover the motherboard bent.I don't know where else to get it. Kindly help me out. My email is johnsonajen@gmail.com thanks🙏
Ajen Johnson - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 11
30 derniers jours : 24
Total : 336
