Aller au contenu principal
Heyday Round Bluetooth Speaker Subwoofer Replacement
Ce dont vous avez besoin
  1. Heyday Round Bluetooth Speaker Subwoofer Replacement, Heyday Round Bluetooth Speaker: étape 1, image 1 de 2 Heyday Round Bluetooth Speaker Subwoofer Replacement, Heyday Round Bluetooth Speaker: étape 1, image 2 de 2
    • Use a metal spudger to pry the fabric-covered top off of the speaker.
  2. Heyday Round Bluetooth Speaker Subwoofer Replacement: étape 2, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the twelve screws around the perimeter of the inner plastic shell.
  3. Heyday Round Bluetooth Speaker Subwoofer Replacement: étape 3, image 1 de 1
    • Remove the inner shell from the back case.
    • Don't yank or pull the shell case off the bottom case. There are cables connecting the two and they could be damaged if pulled.
  4. Heyday Round Bluetooth Speaker Subwoofer Replacement: étape 4, image 1 de 1
    • Once the hardware is opened by the screwdriver, both sides of the motherboard will be exposed and ready for any needed repairs.
  5. Heyday Round Bluetooth Speaker Subwoofer Replacement, Subwoofer: étape 5, image 1 de 2 Heyday Round Bluetooth Speaker Subwoofer Replacement, Subwoofer: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    • Use curved tip tweezers to detach the connectors of two 2-prong Aux In/Out plugs extending from the subwoofer.
  6. Heyday Round Bluetooth Speaker Subwoofer Replacement: étape 6, image 1 de 2 Heyday Round Bluetooth Speaker Subwoofer Replacement: étape 6, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the four screws at the edge of each subwoofer to release them.
    • Remove both subwoofers.
Jonathan Sotelo
Membre depuis le 09/22/22
302 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 4
Total : 174
