Introduction
If you need to replace the motor of your Heyday Suitcase Turntable, follow this guide.
If the turntable does not spin when the device is on and has power, it may be because the motor is damaged or faulty and needs to be replaced.
Before beginning this repair, be sure turn the device off and unplugged from the power cord.
Ce dont vous avez besoin
Using angled tweezers or a Halberd spudger, pry the spindle shaft from the spindle.
Use a Phillips #2 screwdriver to remove the four screws on each corner of the baseboard.
Use a Phillips #1 screwdriver to remove the screws connecting the motor and the baseboard.
