Aller au contenu principal
Heyday Wireless Bluetooth Speaker 9979 Battery Replacement
Ce dont vous avez besoin
  1. Heyday Wireless Bluetooth Speaker 9979 Battery Replacement, Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: étape 1, image 1 de 1
    • Remove the four bezels from the speaker's back cover.
    • Try to get under the bezel by using force, and pull it out little by little.
  2. Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: étape 2, image 1 de 1
    • Use a Phillips #1 screwdriver to remove the four 1.6 mm screws. Rotate the driver counterclockwise to remove the screws.
  3. Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: étape 3, image 1 de 2 Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: étape 3, image 2 de 2
    • Remove the cover of the wireless speaker using the metal spudger. Don't use much force to remove it.
  4. Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: étape 4, image 1 de 2 Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: étape 4, image 2 de 2
    • Once you have pulled the cover to the side, remove the two screws with a Philips #000 screwdriver. Turn counterclockwise.
  5. Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: étape 5, image 1 de 2 Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: étape 5, image 2 de 2
    • The battery might be glued down so use the black nylon spundger to take it out completely.
  6. Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: étape 6, image 1 de 3 Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: étape 6, image 2 de 3 Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    • Using the nylon tipped tweezers, remove the motherboard carefully. It is recommended to grab the motherboard in the middle as there are no big buttons on it.
  7. Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: étape 7, image 1 de 3 Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: étape 7, image 2 de 3 Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: étape 7, image 3 de 3
    • You want to remove the white power cable connector from the motherboard. Start by using the fixit opening pick to pull it up. Once it is almost out, use you're fingers to just simply disconnect it.
Thanh Duong
Membre depuis le 09/26/22
195 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 5-4, Adachi Fall 2022 Membre de l'équipe CSU Los Angeles, Team 5-4, Adachi Fall 2022
CSULA-ADACHI-F22S5G4
5 membres
2 tutoriels rédigés
4 commentaires
The grammar could be improved by simplifying the steps (not using too many words or try separating into multiple bullet points) and avoiding the use of ambiguous pronouns (it).
Jadealyn Paulino - Réponse
Will do, thanks!
Chris Yepez -
There are a lot of images and some are the same.
Cindy Munoz - Réponse
The description of each tool needed was a very useful touch.
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 25
Total : 652
