Aller au contenu principal
High Heel Buckle Replacement
Ce dont vous avez besoin
  1. High Heel Buckle Replacement, Elastic Strap Buckle: étape 1, image 1 de 3 High Heel Buckle Replacement, Elastic Strap Buckle: étape 1, image 2 de 3 High Heel Buckle Replacement, Elastic Strap Buckle: étape 1, image 3 de 3
    • Cut through the remaining thread of the elastic strap.
    • Remove the strap buckle to adjust the position.
    • This step is only if the elastic strap is still attached by any little thread. If the buckle is already detached, skip to step two.
  2. High Heel Buckle Replacement: étape 2, image 1 de 2 High Heel Buckle Replacement: étape 2, image 2 de 2
    • Slide the end of the strap underneath the buckle frame without the center prong.
  3. High Heel Buckle Replacement: étape 3, image 1 de 2 High Heel Buckle Replacement: étape 3, image 2 de 2
    • Lift the center buckle prong vertically and place it into the center of the strap elastic.
  4. High Heel Buckle Replacement: étape 4, image 1 de 1
    • Continue pushing the strap elastic down underneath the other side buckle frame.
  5. High Heel Buckle Replacement: étape 5, image 1 de 2 High Heel Buckle Replacement: étape 5, image 2 de 2
    • Fold the detached elastic strap together with the strap attached to the heel so that both straps are evenly lined up.
  6. High Heel Buckle Replacement: étape 6, image 1 de 3 High Heel Buckle Replacement: étape 6, image 2 de 3 High Heel Buckle Replacement: étape 6, image 3 de 3
    • With a threaded needle, sew along the ends of the straps in order to enclose the buckle in place.
    • Avoid poking your fingers with the needle.
  7. High Heel Buckle Replacement: étape 7, image 1 de 2 High Heel Buckle Replacement: étape 7, image 2 de 2
    • Test out the buckle to ensure it is lined properly and can now strap the heel.
Ligne d'arrivée
Natalya Daranutsa
Membre depuis le 01/06/21
145 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 47
30 derniers jours : 198
Total : 8,573
