Aller au contenu principal
HoMedics TotalComfort UHE-CM18 Control Panel Replacement
Ce dont vous avez besoin
  1. HoMedics TotalComfort UHE-CM18 Control Panel Replacement, Control Panel: étape 1, image 1 de 2 HoMedics TotalComfort UHE-CM18 Control Panel Replacement, Control Panel: étape 1, image 2 de 2
    • Lift up the water tank and separate it from the humidifier.
    • Flip the humidifier over to its underside.
  2. HoMedics TotalComfort UHE-CM18 Control Panel Replacement: étape 2, image 1 de 2 HoMedics TotalComfort UHE-CM18 Control Panel Replacement: étape 2, image 2 de 2
    • Use the Phillips #1 screwdriver to remove the two 7 mm screws that secure the AC power plug.
    • Remove the AC power plug cover.
  3. HoMedics TotalComfort UHE-CM18 Control Panel Replacement: étape 3, image 1 de 2 HoMedics TotalComfort UHE-CM18 Control Panel Replacement: étape 3, image 2 de 2
    • Remove the remaining four 7mm screws that hold the bottom cover.
    • Remove the bottom cover.
  4. HoMedics TotalComfort UHE-CM18 Control Panel Replacement: étape 4, image 1 de 3 HoMedics TotalComfort UHE-CM18 Control Panel Replacement: étape 4, image 2 de 3 HoMedics TotalComfort UHE-CM18 Control Panel Replacement: étape 4, image 3 de 3
    • Disconnect the two white cables by pushing down the center tab at the end and pulling it out of its socket.
  5. HoMedics TotalComfort UHE-CM18 Control Panel Replacement: étape 5, image 1 de 2 HoMedics TotalComfort UHE-CM18 Control Panel Replacement: étape 5, image 2 de 2
    • Remove the three 7mm screws that attach the control panel to the case.
    • Remove the control panel from the case.
Johny
Membre depuis le 09/08/23
557 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 142
