Aller au contenu principal
HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement
Ce dont vous avez besoin
  1. HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement, Power Supply Board: étape 1, image 1 de 2 HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement, Power Supply Board: étape 1, image 2 de 2
    • Lift up the water tank and separate it from the humidifier.
    • Flip the humidifier over to its underside.
  2. HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: étape 2, image 1 de 2 HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: étape 2, image 2 de 2
    • Use the Phillips #1 screwdriver to remove the two 7 mm screws that secure the AC power plug.
    • Remove the AC power plug cover.
  3. HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: étape 3, image 1 de 2 HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: étape 3, image 2 de 2
    • Remove the remaining four 7 mm screws that hold the bottom cover.
    • Remove the bottom cover.
  4. HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: étape 4, image 1 de 3 HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: étape 4, image 2 de 3 HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: étape 4, image 3 de 3
    • Disconnect the two cables with the red and white ends by pushing down the center tab at the end and pulling them out of their sockets.
  5. HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: étape 5, image 1 de 1
    • Remove the power supply board.
Johny
Membre depuis le 09/08/23
557 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 9
Total : 101
