Aller au contenu principal
Holley 4 Barrel Carburetor Gasket Replacement
Ce dont vous avez besoin
  1. Holley 4 Barrel Carburetor Gasket Replacement, Gaskets: étape 1, image 1 de 3 Holley 4 Barrel Carburetor Gasket Replacement, Gaskets: étape 1, image 2 de 3 Holley 4 Barrel Carburetor Gasket Replacement, Gaskets: étape 1, image 3 de 3
    • Make sure your carburetor has no fuel inside.
  2. Holley 4 Barrel Carburetor Gasket Replacement: étape 2, image 1 de 1
    • Remove the four 47 mm flat head screws.
  3. Holley 4 Barrel Carburetor Gasket Replacement: étape 3, image 1 de 1
    • Remove the bowl from the side of the carburetor.
  4. Holley 4 Barrel Carburetor Gasket Replacement: étape 4, image 1 de 1
    • Remove the four 63 mm flat head screws.
  5. Holley 4 Barrel Carburetor Gasket Replacement: étape 5, image 1 de 1
    • Remove the bowl and the steel fuel line from the side of the carburetor.
  6. Holley 4 Barrel Carburetor Gasket Replacement: étape 6, image 1 de 2 Holley 4 Barrel Carburetor Gasket Replacement: étape 6, image 2 de 2
    • Remove the spacer from the side of the carburetor.
    • If you need to, use a flat head screwdriver and carefully pry the spacer off of the carburetor.
  7. Holley 4 Barrel Carburetor Gasket Replacement: étape 7, image 1 de 1
    • Remove the six 2.5 mm hex screws from the secondary metering block.
    • If you need to, use the small flat head screwdriver that will fit the head of the hex screws in order to remove the screws.
  8. Holley 4 Barrel Carburetor Gasket Replacement: étape 8, image 1 de 1
    • Using a flat head screwdriver, remove the thin gasket from the side of the carburetor.
  9. Holley 4 Barrel Carburetor Gasket Replacement: étape 9, image 1 de 2 Holley 4 Barrel Carburetor Gasket Replacement: étape 9, image 2 de 2
    • Remove the eight 20 mm Phillips screws from the bottom plate of the carburetor.
    • Then, carefully remove the gasket from the bottom plate. Use a flat head screwdriver, if needed, to pry the gasket off of the plate.
4 autres ont terminé cette réparation.
Chad Giesmann
Membre depuis le 06/01/16
186 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 33
Total : 4,463
