Aller au contenu principal
Homelite UT44172 Plastic Casing Replacement
Ce dont vous avez besoin
  1. Homelite UT44172 Plastic Casing Replacement, Opening Device: étape 1, image 1 de 1
    • Remove the six 15 mm screws from the shear using a Phillips #2 screwdriver.
  2. Homelite UT44172 Plastic Casing Replacement, Remove Faceplate: étape 2, image 1 de 2 Homelite UT44172 Plastic Casing Replacement, Remove Faceplate: étape 2, image 2 de 2
    • Pull the faceplate away from the body of the device and replace it with the new faceplate.
    • Potential for device damage: Be sure to take caution of loose wires during the replacement process.
    • If the plate with the screw sockets was replaced, the wires will need to be put back into the the depressions on the new plate for the device to be closed up properly. See photo with the blades on the right for proper wire placement.
Adam soto
Membre depuis le 01/30/15
301 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 17-5, Watkins Winter 2015 Membre de l'équipe USF Tampa, Team 17-5, Watkins Winter 2015
USFT-WATKINS-W15S17G5
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 15
Total : 232
