Aller au contenu principal
Homelite UT44172 Safety Switch Replacement
Ce dont vous avez besoin
  1. Homelite UT44172 Safety Switch Replacement, Opening the device: étape 1, image 1 de 1
    • Remove the six 1.5 cm screws marked on the picture from the plastic casing with a Phillips #2 screwdriver.
  2. Homelite UT44172 Safety Switch Replacement, Remove Faceplate: étape 2, image 1 de 1
    • Remove the faceplate to expose the inner mechanisms.
  3. Homelite UT44172 Safety Switch Replacement, Switch Removal: étape 3, image 1 de 3 Homelite UT44172 Safety Switch Replacement, Switch Removal: étape 3, image 2 de 3 Homelite UT44172 Safety Switch Replacement, Switch Removal: étape 3, image 3 de 3
    • Remove the safety switch by pulling it away from the body of device.
    • Be careful not to lose the spring, which is under pressure and may fly out during removal.
  4. Homelite UT44172 Safety Switch Replacement, Spring Replacement: étape 4, image 1 de 1
    • Inspect both the spring and the switch to see if either is deformed or damaged. If so, replace the damaged part with a new part.
    • During reassembly, gently move the inner wires out of the way so they do not get caught in the spring.
Daniel Endericavillacis
Membre depuis le 01/25/15
101 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 17-5, Watkins Winter 2015 Membre de l'équipe USF Tampa, Team 17-5, Watkins Winter 2015
USFT-WATKINS-W15S17G5
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 5
Total : 323
