Aller au contenu principal
Honda CSC29 Alternator Cover Removal
Ce dont vous avez besoin
  1. Honda CSC29 Alternator Cover Removal, Alternator Front Cover: étape 1, image 1 de 3 Honda CSC29 Alternator Cover Removal, Alternator Front Cover: étape 1, image 2 de 3 Honda CSC29 Alternator Cover Removal, Alternator Front Cover: étape 1, image 3 de 3
    • Remove 4, 7.9mm nuts using a 7.9mm socket driver head
    • One of the nuts is placed underneath the L-Bracket. Remove the L-Bracket and the 3 circled nuts before attempting to remove the remaining nut
    • There are two covers that need to be removed from the alternator. This step describes how to remove the back cover.
  2. Honda CSC29 Alternator Cover Removal: étape 2, image 1 de 3 Honda CSC29 Alternator Cover Removal: étape 2, image 2 de 3 Honda CSC29 Alternator Cover Removal: étape 2, image 3 de 3
    • Pull cover off the body of the alternator
    • Once you have done this, you should be able to see the internal components of the alternator, particularly the bridge assembly that houses the rectifier, voltage regulator and brushes.
8 autres ont terminé cette réparation.
Chad Lagomarsino
Membre depuis le 04/14/16
563 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 25-1, Maness Spring 2016 Membre de l'équipe Cal Poly, Team 25-1, Maness Spring 2016
CPSU-MANESS-S16S25G1
4 membres
15 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 34
Total : 1,845
