Aller au contenu principal
Honda S2000 VTEC Solenoid Upper Replacement
Ce dont vous avez besoin
  1. Honda S2000 VTEC Solenoid Upper Replacement, VTEC Solenoid Upper: étape 1, image 1 de 2 Honda S2000 VTEC Solenoid Upper Replacement, VTEC Solenoid Upper: étape 1, image 2 de 2
    • Locate Vtec Solenoid on front left of engine.
  2. Honda S2000 VTEC Solenoid Upper Replacement: étape 2, image 1 de 3 Honda S2000 VTEC Solenoid Upper Replacement: étape 2, image 2 de 3 Honda S2000 VTEC Solenoid Upper Replacement: étape 2, image 3 de 3
    • Locate and remove 3 bolts.
    • Do not drop cable that is attached by a bolt.
  3. Honda S2000 VTEC Solenoid Upper Replacement: étape 3, image 1 de 3 Honda S2000 VTEC Solenoid Upper Replacement: étape 3, image 2 de 3 Honda S2000 VTEC Solenoid Upper Replacement: étape 3, image 3 de 3
    • Pull the plug upwards off of metal cable holder, and then disconnect the two cables.
  4. Honda S2000 VTEC Solenoid Upper Replacement: étape 4, image 1 de 3 Honda S2000 VTEC Solenoid Upper Replacement: étape 4, image 2 de 3 Honda S2000 VTEC Solenoid Upper Replacement: étape 4, image 3 de 3
    • Remove the metal cable holder and set it to the side.
    • Pull off the upper Vtec Solenoid.
  5. Honda S2000 VTEC Solenoid Upper Replacement: étape 5, image 1 de 3 Honda S2000 VTEC Solenoid Upper Replacement: étape 5, image 2 de 3 Honda S2000 VTEC Solenoid Upper Replacement: étape 5, image 3 de 3
    • Grab a new replacement upper Solenoid.
    • Place the gasket (new or used if still good) into its slot.
    • Spread a small amount of oil all along the gasket.
  6. Honda S2000 VTEC Solenoid Upper Replacement: étape 6, image 1 de 2 Honda S2000 VTEC Solenoid Upper Replacement: étape 6, image 2 de 2
    • Insert wisdom here.
  7. Honda S2000 VTEC Solenoid Upper Replacement: étape 7, image 1 de 3 Honda S2000 VTEC Solenoid Upper Replacement: étape 7, image 2 de 3 Honda S2000 VTEC Solenoid Upper Replacement: étape 7, image 3 de 3
    • Grab metal cable holder and place one of the bolts into it.
    • Hand tighten all three bolts.
    • Ensure the metal cable holder is straight.
  8. Honda S2000 VTEC Solenoid Upper Replacement: étape 8, image 1 de 3 Honda S2000 VTEC Solenoid Upper Replacement: étape 8, image 2 de 3 Honda S2000 VTEC Solenoid Upper Replacement: étape 8, image 3 de 3
    • Tighten all 3 bolts with a ratchet.
    • Plug the cable back in, and attach it to the metal holder.
  9. Honda S2000 VTEC Solenoid Upper Replacement: étape 9, image 1 de 2 Honda S2000 VTEC Solenoid Upper Replacement: étape 9, image 2 de 2
    • Wipe down the edges where the two parts meet to pick up any oil that may have spilled.
    • Keep a eye on solenoid for any oil leaking after cleaning.
You now have a proper working Solenoid, Just make sure to keep an eye on the solenoid in case of any oil leaks
Angeljauregui
Membre depuis le 03/12/24
169 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 1-17, Harris Spring 2024 Membre de l'équipe CSU Los Angeles, Team 1-17, Harris Spring 2024
CSULA-HARRIS-S24S1G17
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 40
Total : 97
