Aller au contenu principal
Honeywell HY-204 Control Panel Replacement
Ce dont vous avez besoin
  1. Honeywell HY-204 Control Panel Replacement, Case: étape 1, image 1 de 2 Honeywell HY-204 Control Panel Replacement, Case: étape 1, image 2 de 2
    • Before you begin, be sure to unplug the fan.
    • Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
  2. Honeywell HY-204 Control Panel Replacement: étape 2, image 1 de 2 Honeywell HY-204 Control Panel Replacement: étape 2, image 2 de 2
    • Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
  3. Honeywell HY-204 Control Panel Replacement, Control Panel: étape 3, image 1 de 2 Honeywell HY-204 Control Panel Replacement, Control Panel: étape 3, image 2 de 2
    • Remove the two 3mm screws found just below the top of the device using the Phillips #0 Screwdriver.
  4. Honeywell HY-204 Control Panel Replacement: étape 4, image 1 de 1
    • Pry off the control panel by forcefully lifting the tab located inside the front of the fan with the plastic opening tool.
Nolan Ernotte
Membre depuis le 10/14/14
384 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 10-40, Amido Fall 2014 Membre de l'équipe Cal Poly, Team 10-40, Amido Fall 2014
CPSU-AMIDO-F14S10G40
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 537
