Introduction
If you are having trouble with your Febreze scent settings, and you are sure that your scent cartridge is full, this is the guide for you! This guide will walk you through replacing the Febreze settings dial. Although this is a quick process, you need to be careful not to accidentally separate the wires from the dial.
Ce dont vous avez besoin
Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
Remove the two 3mm screws found just below the top of the device using the Phillips #0 Screwdriver.
Remove the two 3mm Phillips #0 screws from the back of the black dial box.
