Aller au contenu principal
Honeywell Pro 3000 Non-Programmable Thermostat Replacement
Ce dont vous avez besoin
  1. Honeywell Pro 3000 Non-Programmable Thermostat Replacement, Thermostat: étape 1, image 1 de 2 Honeywell Pro 3000 Non-Programmable Thermostat Replacement, Thermostat: étape 1, image 2 de 2
    • Find which switch on your circuit breaker is associated with your heating system. The number will match the number next to the breaker.
    • Turn the switch from on to off. Disconnecting the electricity to the thermostat.
  2. Honeywell Pro 3000 Non-Programmable Thermostat Replacement: étape 2, image 1 de 2 Honeywell Pro 3000 Non-Programmable Thermostat Replacement: étape 2, image 2 de 2
    • On the thermostat being replaced. Unscrew each terminal with a Phillips #0 screwdriver until there is enough room for you to pull out each wire. Pull each wire until it is completely removed from terminal.
  3. Honeywell Pro 3000 Non-Programmable Thermostat Replacement: étape 3, image 1 de 1
    • Once all wires are disconnected start to remove the base and wall mount from the wall. Remove each screw using a Phillips #0 screwdriver on both sides of the base and gently pull the base and mount from the wall.
  4. Honeywell Pro 3000 Non-Programmable Thermostat Replacement: étape 4, image 1 de 3 Honeywell Pro 3000 Non-Programmable Thermostat Replacement: étape 4, image 2 de 3 Honeywell Pro 3000 Non-Programmable Thermostat Replacement: étape 4, image 3 de 3
    • To make sure the new thermostat is not crooked along the wall use a level on top of the plate. While holding the plate straight, screw in both 15.24mm X 25.4mm screws using a Phillips #0 screwdriver on the left and right side of the base place until it is fastened against the wall.
  5. Honeywell Pro 3000 Non-Programmable Thermostat Replacement: étape 5, image 1 de 3 Honeywell Pro 3000 Non-Programmable Thermostat Replacement: étape 5, image 2 de 3 Honeywell Pro 3000 Non-Programmable Thermostat Replacement: étape 5, image 3 de 3
    • Place each colored wire gently into the corresponding terminal port until you can feel it hit the bottom of each port. All of the terminal ports are assigned by the first letter of each color coated wire.
    • It is not necessary to plug the blue wire in if you are using batteries for the thermostat.
  6. Honeywell Pro 3000 Non-Programmable Thermostat Replacement: étape 6, image 1 de 3 Honeywell Pro 3000 Non-Programmable Thermostat Replacement: étape 6, image 2 de 3 Honeywell Pro 3000 Non-Programmable Thermostat Replacement: étape 6, image 3 de 3
    • Once all the wires are placed into the corresponding ports continue to secure the connection by using a flat head screwdriver to tighten the wires into the ports.
    • Once completed place the actual thermostat on the base plate.
  7. Honeywell Pro 3000 Non-Programmable Thermostat Replacement: étape 7, image 1 de 3 Honeywell Pro 3000 Non-Programmable Thermostat Replacement: étape 7, image 2 de 3 Honeywell Pro 3000 Non-Programmable Thermostat Replacement: étape 7, image 3 de 3
    • Go to the circuit breaker and turn the electricity back onto the furnace and thermostat.
    • Mount the thermostat onto the wall plate and give the thermostat a test run to see if it functioning correctly.
If the thermostat is not functioning as intended, take apart and reinstall making sure wire connections are secure.
Samuel Covert
Membre depuis le 03/23/20
145 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 28
Total : 3,098
