Introduction
The hose creates a pathway for water to flow from the dirty and clean water tanks on your Hoover Power Path Pro Advanced. However, if there is a puncture in the hose, then it needs to be replaced.
Pièces
Aucune pièce nécessaire.
Unplug the vacuum cleaner from the wall outlet before starting.  Make sure the water tanks are empty.
  • Unplug the vacuum cleaner from the wall outlet before starting. Make sure the water tanks are empty.
  • Lay the cleaner down horizontally with its wheels closest to the floor.
Ajouter un commentaire
Hold the lower brush roll with both hands and pull outwards until it is detached.
  • Hold the lower brush roll with both hands and pull outwards until it is detached.
  • Unscrew the 6 marked screws using a Phillips #2 head screwdriver.
  • Remove the brush roller.
  • Use a long #2 Philips head screwdriver to remove the 8 numbered screws on the bottom of the cleaner.
    • They will also be indicated on the bottom of the vacuum.
  • Pull the red handle shown to remove the front suction unit from the cleaner.
  • Unscrew the Phillips #2 screw at the bottom of the hose.
  • Grab the attachment at tip of the hose and unscrew it. Pull outwards on the hose until completely removed.
Équipe
Cal Poly, Team S16-G5, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S16-G5, Banghart Winter 2018
CPSU-BANGHART-W18S16G5
5 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 54
Total : 244
