Aller au contenu principal
Hori Real Arcade Pro N Push Button Replacement
Ce dont vous avez besoin
  1. Hori Real Arcade Pro N Push Button Replacement, Push Button: étape 1, image 1 de 2 Hori Real Arcade Pro N Push Button Replacement, Push Button: étape 1, image 2 de 2
    • Flip your Fight Stick so the bottom is facing up.
    • Remove the sticker covering the screw in the bottom middle of the device.
    • Remove eight screws from the bottom of the device using a Phillips #0 screwdriver.
  2. Hori Real Arcade Pro N Push Button Replacement: étape 2, image 1 de 2 Hori Real Arcade Pro N Push Button Replacement: étape 2, image 2 de 2
    • Find the storage compartment that holds the USB wire.
    • Open the case by putting your hand in the compartment and pushing up.
    • Put your Fight Stick on its side to make the other steps easier.
  3. Hori Real Arcade Pro N Push Button Replacement: étape 3, image 1 de 2 Hori Real Arcade Pro N Push Button Replacement: étape 3, image 2 de 2
    • Use your fingers to pull the black grip to detach both wires connected to the pushbutton.
    • Pulling the wire instead of the black grip can cause the wires to not function.
  4. Hori Real Arcade Pro N Push Button Replacement: étape 4, image 1 de 2 Hori Real Arcade Pro N Push Button Replacement: étape 4, image 2 de 2
    • Twist the button you are planning to remove.
    • The tabs must be on its side as shown in the second picture so it is easier to grab in the next step.
  5. Hori Real Arcade Pro N Push Button Replacement: étape 5, image 1 de 3 Hori Real Arcade Pro N Push Button Replacement: étape 5, image 2 de 3 Hori Real Arcade Pro N Push Button Replacement: étape 5, image 3 de 3
    • Squeeze the tabs in the button.
    • While squeezing, push the button inward, so it falls out.
gabriel garcia
Membre depuis le 01/24/22
148 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 21-17, Briggs Spring 2022 Membre de l'équipe CSU Los Angeles, Team 21-17, Briggs Spring 2022
CSULA-BRIGGS-S22S21G17
1 membre
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 6
30 derniers jours : 21
Total : 1,925
