Aller au contenu principal
Hot Tools HPK12 Control Assembly Replacement
Ce dont vous avez besoin
  1. Hot Tools HPK12 Control Assembly Replacement, Prerequisite Only: étape 1, image 1 de 3 Hot Tools HPK12 Control Assembly Replacement, Prerequisite Only: étape 1, image 2 de 3 Hot Tools HPK12 Control Assembly Replacement, Prerequisite Only: étape 1, image 3 de 3
    • Remove round plastic cover near cord base by prying under the side with the metal spudger.
    • Flip the device and remove the other round plastic cover near the base of the cord.
    • Use the Phillips #1 screwdriver to remove the 5.5mm PH1 screw and washer under the plastic cover and set both aside.
  2. Hot Tools HPK12 Control Assembly Replacement: étape 2, image 1 de 1
    • Use the metal spudger to push the center pin through to the other side.
  3. Hot Tools HPK12 Control Assembly Replacement: étape 3, image 1 de 2 Hot Tools HPK12 Control Assembly Replacement: étape 3, image 2 de 2
    • Lift back plastic cover to expose spring assembly.
    • Be careful not to damage the power cord by bending or twisting it too much while performing this step.
    • Grip the exposed end of the spring assembly and remove it.
    • The side with the two ends of the spring goes into the recessed area of the iron
  4. Hot Tools HPK12 Control Assembly Replacement: étape 4, image 1 de 1
    • Use the JIS #0 screwdriver to remove the two 3.5mm “J0” screws that attach the control assembly cover to the flat iron base.
  5. Hot Tools HPK12 Control Assembly Replacement: étape 5, image 1 de 3 Hot Tools HPK12 Control Assembly Replacement: étape 5, image 2 de 3 Hot Tools HPK12 Control Assembly Replacement: étape 5, image 3 de 3
    • Lift upward on the control assembly cover to remove it from the flat iron base.
    • Remove dial and switch cover and set aside.
  6. Hot Tools HPK12 Control Assembly Replacement: étape 6, image 1 de 3 Hot Tools HPK12 Control Assembly Replacement: étape 6, image 2 de 3 Hot Tools HPK12 Control Assembly Replacement: étape 6, image 3 de 3
    • Use your JIS #0 screw driver to remove the two 6mm “J0” screws that are attached to the flat iron base and set them aside.
    • Lift the backing plate upwards to remove it from the flat iron.
    • Use the Phillips #0 screwdriver to remove two 4mm “PH0” screws that attach the circuit assembly to the flat iron base.
Aaron Whitlock
Membre depuis le 10/24/16
249 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 3-4, Baechle Fall 2016 Membre de l'équipe IUPUI, Team 3-4, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G4
4 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 31
Total : 2,830
