Introduction
Below we have outlined a few issues that we plan to address based on the research that we have conducted.
- Heating coil burn out
- Temperature control switch burn out
- On/Off switch burn out
Ce dont vous avez besoin
Ensure that you have a clean work station, and that you can easily keep track of small, loose parts.
In addition, MAKE SURE IT IS UNPLUGGED FOR ALL FOLLOWING STEPS!
Firmly grasp the end of the Iron with the black plastic cap on the heating element end.
With your free hand, use tweezers to firmly grasp the small retaining ring sitting between the heating element and the handle body.
Once you have a firm grasp, pull up on the retaining ring, and it should come loose.
Remove the board gently from its location. Note how its shape fits its location for easy assembling.
The white cable is the heating coil. It is powered through the board by the power switch. It has three small wires that are soldered on the board.
Desolder the three wires as shown on the picture. Mark the location of each wire.
Refer to Hot Tools Professional 1110 Power Switch Replacement for more guidelines.
