Aller au contenu principal
Pour réparer ensemble - Je crée un compte
House Door Lock Cylinder Replacement
Ce dont vous avez besoin
    1. House Door Lock Cylinder Replacement, Lock Cylinder: étape 1, image 1 de 1
      • Push out the retaining pin from the inside and remove the door knob.
      Demander à FixBot
      Ajouter un commentaire
    2. House Door Lock Cylinder Replacement: étape 2, image 1 de 1
      • Unscrew and remove the decorative cover.
      Demander à FixBot
    3. House Door Lock Cylinder Replacement: étape 3, image 1 de 1
      • Remove the two mounting screws and pull the lock body out from the outside.
      Demander à FixBot
    4. House Door Lock Cylinder Replacement: étape 4, image 1 de 1
      • Locate the slot on the lock body that engages with the lock cylinder.
      • Turn the knob to retract the latch bolt and open the door.
      • Note its position for reassembly.
      Demander à FixBot
    5. House Door Lock Cylinder Replacement: étape 5, image 1 de 1
      • Remove the lock cylinder fixing screw.
      • Keep all removed screws and small parts organized for reassembly.
      Demander à FixBot
    6. House Door Lock Cylinder Replacement: étape 6, image 1 de 1
      • Take out the lock cylinder.
      Demander à FixBot
    7. House Door Lock Cylinder Replacement: étape 7, image 1 de 1
      • Compare the replacement lock cylinder with the original.
      • Prepare a replacement lock cylinder of the same size and ensure the correct installation orientation.
      Demander à FixBot
    8. House Door Lock Cylinder Replacement: étape 8, image 1 de 1
      • Insert the new lock cylinder into the door opening and secure it with the fixing screw.
      Demander à FixBot
    9. House Door Lock Cylinder Replacement: étape 9, image 1 de 3 House Door Lock Cylinder Replacement: étape 9, image 2 de 3 House Door Lock Cylinder Replacement: étape 9, image 3 de 3
      • Reinstall the lock body from the outside.
      • Make sure the slot properly engages with the lock cylinder.
      • Then turn the exterior knob and verify that the latch retracts normally.
      Demander à FixBot
    10. House Door Lock Cylinder Replacement: étape 10, image 1 de 1
      • Tighten the adjustment screws for both the interior and exterior knobs.
      • Tighten the decorative cover of the interior knob.
      Demander à FixBot
    11. House Door Lock Cylinder Replacement: étape 11, image 1 de 1
      • Push the knob firmly inward until it is fully seated in place.
      Demander à FixBot
    12. House Door Lock Cylinder Replacement: étape 12, image 1 de 1
      • Turn both the interior and exterior knobs to verify that the latch operates correctly and the door opens normally.
      Demander à FixBot
Ligne d'arrivée
Harry
Membre depuis le 05/13/26
205 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 3-6, Whithaus Spring 2026 Membre de l'équipe UC Davis, Team 3-6, Whithaus Spring 2026
UCD-WHITHAUS-S26S3G6
3 membres
12 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 45
30 derniers jours : 139
Total : 305
