Aller au contenu principal
Hover 1 Eclipse Battery Replacement
  1. Hover 1 Eclipse Battery Replacement, Battery: étape 1, image 1 de 3 Hover 1 Eclipse Battery Replacement, Battery: étape 1, image 2 de 3 Hover 1 Eclipse Battery Replacement, Battery: étape 1, image 3 de 3
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the plug side bottom shell piece.
    • Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the plug side bottom shell piece.
    • Remove the right side bottom shell piece.
  2. Hover 1 Eclipse Battery Replacement: étape 2, image 1 de 2 Hover 1 Eclipse Battery Replacement: étape 2, image 2 de 2
    • Locate the black and red wires connected by an yellow header, Xt60.
    • This wire connects the battery to the motherboard.
    • Carefully tug on the two sides of the yellow header to disconnect them.
  3. Hover 1 Eclipse Battery Replacement: étape 3, image 1 de 3 Hover 1 Eclipse Battery Replacement: étape 3, image 2 de 3 Hover 1 Eclipse Battery Replacement: étape 3, image 3 de 3
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that secure the black plastic keeping the battery in place.
    • Carefully remove the black plastic from the hoverboard.
    • Be mindful of the wires surrounding the battery.
  4. Hover 1 Eclipse Battery Replacement: étape 4, image 1 de 2 Hover 1 Eclipse Battery Replacement: étape 4, image 2 de 2
    • Be careful with the wires surrounding the battery when executing this step.
    • The battery is attached to the metal with an adhesive.
    • Firmly grasp the battery and tug on it until it is free from the metal.
Mina Dedijer
Membre depuis le 10/10/19
545 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S12-G4, Regan Fall 2019 Membre de l'équipe Cal Poly, Team S12-G4, Regan Fall 2019
CPSU-REGAN-F19S12G4
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 26
Total : 2,246
