Aller au contenu principal
Hover 1 Eclipse Bluetooth Speaker Replacement
Ce dont vous avez besoin
  1. Hover 1 Eclipse Bluetooth Speaker Replacement, Bluetooth Speaker: étape 1, image 1 de 3 Hover 1 Eclipse Bluetooth Speaker Replacement, Bluetooth Speaker: étape 1, image 2 de 3 Hover 1 Eclipse Bluetooth Speaker Replacement, Bluetooth Speaker: étape 1, image 3 de 3
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the plug side bottom shell piece.
    • Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the plug side bottom shell piece.
    • Remove the plug side bottom shell piece
  2. Hover 1 Eclipse Bluetooth Speaker Replacement: étape 2, image 1 de 3 Hover 1 Eclipse Bluetooth Speaker Replacement: étape 2, image 2 de 3 Hover 1 Eclipse Bluetooth Speaker Replacement: étape 2, image 3 de 3
    • within the plug side shell piece, there are two white and pink wires connecting the shell and the motherboard.
    • On the circuit board by the speaker, carefully squeeze and unplug the small white headers that connect the shell piece to the hoverboard body.
    • On the body of the board, follow the wires that connect the lights to the motherboard. Disconnect these wires from the motherboard by squeezing and pulling the small white headers.
    • Now you can fully remove the shell piece.
  3. Hover 1 Eclipse Bluetooth Speaker Replacement: étape 3, image 1 de 3 Hover 1 Eclipse Bluetooth Speaker Replacement: étape 3, image 2 de 3 Hover 1 Eclipse Bluetooth Speaker Replacement: étape 3, image 3 de 3
    • Using a Phillips #0 Screwdriver, remove the 3 screws holding the speaker to the shell.
    • Lift the speaker out from the casing.
Mina Dedijer
Membre depuis le 10/10/19
545 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S12-G4, Regan Fall 2019 Membre de l'équipe Cal Poly, Team S12-G4, Regan Fall 2019
CPSU-REGAN-F19S12G4
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 12
Total : 324
