Aller au contenu principal
Hover 1 Eclipse Motherboard Replacement
Ce dont vous avez besoin
  1. Hover 1 Eclipse Motherboard Replacement, Motherboard: étape 1, image 1 de 3 Hover 1 Eclipse Motherboard Replacement, Motherboard: étape 1, image 2 de 3 Hover 1 Eclipse Motherboard Replacement, Motherboard: étape 1, image 3 de 3
    • Using a Phillips #1 Screwdriver, remove the eight 11mm screws that surround the edge of each shell piece.
    • Using a Phillips #1 Screwdriver, remove the eight 13mm screws that surround the edge of both shell pieces.
    • Remove the right side bottom shell piece.
  2. Hover 1 Eclipse Motherboard Replacement: étape 2, image 1 de 3 Hover 1 Eclipse Motherboard Replacement: étape 2, image 2 de 3 Hover 1 Eclipse Motherboard Replacement: étape 2, image 3 de 3
    • On the bottom, left side, shell pieces, there are some white and pink wires connecting the shell and the motherboard.
    • On the circuit board by the speaker, carefully squeeze and unplug the small white headers that connect the shell piece to the hoverboard body.
    • Follow the wires that connect the lights to the motherboard. Disconnect these wires from the motherboard by squeezing and pulling the small white headers.
    • Now you can fully remove the bottom left shell piece.
  3. Hover 1 Eclipse Motherboard Replacement: étape 3, image 1 de 1
    • Unplug the yellow tipped plug, Xt60, attached to the red and black cord on the non-battery side.
  4. Hover 1 Eclipse Motherboard Replacement: étape 4, image 1 de 3 Hover 1 Eclipse Motherboard Replacement: étape 4, image 2 de 3 Hover 1 Eclipse Motherboard Replacement: étape 4, image 3 de 3
    • Unplug the yellow tipped plug attached to the red and black cords.
    • Unplug the black headers attached to the white, skinny cord.
    • Unplug the green, blue and yellow plugs by pressing down the silver, under the clear plastic and pulling it apart.
  5. Hover 1 Eclipse Motherboard Replacement: étape 5, image 1 de 2 Hover 1 Eclipse Motherboard Replacement: étape 5, image 2 de 2
    • Unplug the white header attached to the pink and white cord.
    • Using a Phillips #1 screwdriver, remove the four screws from each corner of the motherboard.
    • Repeat steps 3 and 4 on the other side.
  6. Hover 1 Eclipse Motherboard Replacement: étape 6, image 1 de 1
    • You have now removed the motherboards from both sides.
Mina Dedijer
Membre depuis le 10/10/19
545 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S12-G4, Regan Fall 2019 Membre de l'équipe Cal Poly, Team S12-G4, Regan Fall 2019
CPSU-REGAN-F19S12G4
4 membres
5 tutoriels rédigés
7 commentaires
Can you please drop links to purchase the 2 motherboards?
Frank - Réponse
Hi
wondering if you know the part numbers and where to obtain the boards?
Dave - Réponse
We’re do you get the boards at I really need them
Ashton Mcalvain - Réponse
We’re do get the boards?
Hector Ortiz - Réponse
Any idea where to buy parts and the price?
william bowen - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 8
30 derniers jours : 16
Total : 1,988
